ArchitectCreating a room finish legend
Command
Path
Create Rm Finish Legend
Tools > Reports
There can be dozens of room finishes assigned within a project file. To obtain a detailed report of all room finish data, first generate a room finish schedule as described in Using preformatted reports. Then generate a detailed legend showing a full description of the finishes using the Create Rm Finish Legend command. This command can only be used after room finishes have been assigned to space objects.
To generate a room finish legend:
Select the command.
The Create Room Finish Legend dialog box opens.
Parameter
Description
Create legend as text block
Adds the legend to the drawing as a text block
Label Indent
Sets the offset from the location title to the item title
Note Indent
Sets the offset from the location title to the item description
Section Spacing
Sets the text spacing between each section
Note Spacing
Sets the text spacing between each item description
Bold Section Titles
Displays the location titles in bold face text
Create legend as worksheet
Adds the legend to the drawing as a worksheet
Worksheet Name
Sets the name of the worksheet
Place worksheet in document
Places the worksheet on the drawing at the next mouse click
Add row between sections
Adds a worksheet row between each location section
Bold section titles
Select whether the legend should be displayed as a text block or as a worksheet. See Inserting text and Creating worksheets.
Display Method
Description
Text block
Define the area for the legend to occupy. Click to set the top left corner of the text block, and then click to set the bottom right corner. The text legend is generated within the defined rectangle.
Worksheet
The worksheet is created with the legend information. If the Place worksheet in document option is selected, click the drawing to set the top left corner of the worksheet.
